주요 콘텐츠로 건너뛰기
Pantech Matrix Motherboard Replacement
필요한 것
  1. Pantech Matrix Motherboard Replacement, Phone Orientation: 1 단계, 이미지 1/1
    • Place phone with screen side facing toward you.
  2. Pantech Matrix Motherboard Replacement, Phone Orientation: 2 단계, 이미지 1/1
    • Flip phone over so screen side is now facing down.
  3. Pantech Matrix Motherboard Replacement, Remove Back Cover: 3 단계, 이미지 1/2 Pantech Matrix Motherboard Replacement, Remove Back Cover: 3 단계, 이미지 2/2
    • Gently slide the backside phone cover off exposing the battery underneath.
  4. Pantech Matrix Motherboard Replacement, Lift Battery: 4 단계, 이미지 1/1
    • Carefully lift the battery up from where the spudger is pointed.
  5. Pantech Matrix Motherboard Replacement, Remove Battery: 5 단계, 이미지 1/1
    • Remove the battery from its dock.
  6. Pantech Matrix Motherboard Replacement, Slide SIM Card Out: 6 단계, 이미지 1/3 Pantech Matrix Motherboard Replacement, Slide SIM Card Out: 6 단계, 이미지 2/3 Pantech Matrix Motherboard Replacement, Slide SIM Card Out: 6 단계, 이미지 3/3
    • Slide the SIM Card out of its dock.
  7. Pantech Matrix Motherboard Replacement, Remove Phone Screws: 7 단계, 이미지 1/2 Pantech Matrix Motherboard Replacement, Remove Phone Screws: 7 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the four 2mm Phillips #000 screws from each corner of the device.
  8. Pantech Matrix Motherboard Replacement, Remove Phone Casing: 8 단계, 이미지 1/2 Pantech Matrix Motherboard Replacement, Remove Phone Casing: 8 단계, 이미지 2/2
    • Rotate the phone so the base is facing you.
    • Use spudger to separate phone casing and inside as shown.
    • Remove the casing carefully and set aside.
  9. Pantech Matrix Motherboard Replacement, Remove Camera Screws: 9 단계, 이미지 1/2 Pantech Matrix Motherboard Replacement, Remove Camera Screws: 9 단계, 이미지 2/2
    • Place phone with exposed motherboard facing you.
    • Use a Phillips screwdriver to remove the five 2mm Phillips #000 screws holding the camera in place.
  10. Pantech Matrix Motherboard Replacement, Expose Keypad: 10 단계, 이미지 1/1
    • Carefully lift up the motherboard to expose the back of the keypad.
  11. Pantech Matrix Motherboard Replacement, Remove Keypad: 11 단계, 이미지 1/2 Pantech Matrix Motherboard Replacement, Remove Keypad: 11 단계, 이미지 2/2
    • Use spudger to gently pry the keypad away from the rest of the phone.
  12. Pantech Matrix Motherboard Replacement, Remove Motherboard: 12 단계, 이미지 1/3 Pantech Matrix Motherboard Replacement, Remove Motherboard: 12 단계, 이미지 2/3 Pantech Matrix Motherboard Replacement, Remove Motherboard: 12 단계, 이미지 3/3
    • Grip the motherboard and gently pull to separate it from the rest of the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Zeel Patel
회원 가입일: 10/13/14
1,078 평판
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 200
