주요 콘텐츠로 건너뛰기
Pantech Matrix Speaker Replacement
필요한 것
  1. Pantech Matrix Speaker Replacement, Phone Orientation: 1 단계, 이미지 1개 중 1개
    • Place phone with screen side facing toward you.
  2. Pantech Matrix Speaker Replacement, Phone Orientation: 2 단계, 이미지 1개 중 1개
    • Flip phone over so screen side is now facing down.
  3. Pantech Matrix Speaker Replacement, Remove Back Cover: 3 단계, 이미지 2개 중 1개 Pantech Matrix Speaker Replacement, Remove Back Cover: 3 단계, 이미지 2개 중 2개
    • Gently slide the backside phone cover off exposing the battery underneath.
  4. Pantech Matrix Speaker Replacement, Lift Battery: 4 단계, 이미지 1개 중 1개
    • Carefully lift the battery up from where the spudger is pointed.
  5. Pantech Matrix Speaker Replacement, Remove Battery: 5 단계, 이미지 1개 중 1개
    • Remove the battery from its dock.
  6. Pantech Matrix Speaker Replacement, Slide SIM Card Out: 6 단계, 이미지 3개 중 1개 Pantech Matrix Speaker Replacement, Slide SIM Card Out: 6 단계, 이미지 3개 중 2개 Pantech Matrix Speaker Replacement, Slide SIM Card Out: 6 단계, 이미지 3개 중 3개
    • Slide the SIM Card out of its dock.
  7. Pantech Matrix Speaker Replacement, Remove Phone Screws: 7 단계, 이미지 2개 중 1개 Pantech Matrix Speaker Replacement, Remove Phone Screws: 7 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the four 2mm Phillips #000 screws from each corner of the device.
  8. Pantech Matrix Speaker Replacement, Remove Phone Casing: 8 단계, 이미지 3개 중 1개 Pantech Matrix Speaker Replacement, Remove Phone Casing: 8 단계, 이미지 3개 중 2개 Pantech Matrix Speaker Replacement, Remove Phone Casing: 8 단계, 이미지 3개 중 3개
    • Rotate the phone so the base is facing you.
    • Use spudger to separate phone casing and inside as shown.
    • Remove the casing carefully and set aside the rest of the phone.
  9. Pantech Matrix Speaker Replacement, Remove Phone Speaker: 9 단계, 이미지 2개 중 1개 Pantech Matrix Speaker Replacement, Remove Phone Speaker: 9 단계, 이미지 2개 중 2개
    • Place the spudger in the notch on the side of the speaker as shown.
    • Use the spudger to gently pry the speaker loose from its dock.
    • Remove the speaker fully from the phone.
결론
작성자
3다른 기여자 명과 함께
Zeel Patel
회원 가입일: 10/13/14
1,096 평판
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 272
