주요 콘텐츠로 건너뛰기
Parrot AR.Drone 2.0 Motor Replacement
필요한 것
동영상 개요
  1. Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: 1 단계, 이미지 1/2 Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: 1 단계, 이미지 2/2
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Motor Replacement: 2 단계, 이미지 1/2 Parrot AR.Drone 2.0 Motor Replacement: 2 단계, 이미지 2/2
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
  3. Parrot AR.Drone 2.0 Motor Replacement: 3 단계, 이미지 1/1
    • Remove the small retaining clip using a plastic opening tool.
    • Be careful as these clips can fly off and can be difficult to find.
  4. Parrot AR.Drone 2.0 Motor Replacement: 4 단계, 이미지 1/3 Parrot AR.Drone 2.0 Motor Replacement: 4 단계, 이미지 2/3 Parrot AR.Drone 2.0 Motor Replacement: 4 단계, 이미지 3/3
    • The propeller, gear, and rod can be removed by simply lifting them off the motor.
  5. Parrot AR.Drone 2.0 Motor Replacement, Motor: 5 단계, 이미지 1/2 Parrot AR.Drone 2.0 Motor Replacement, Motor: 5 단계, 이미지 2/2
    • Disconnect the connector at the bottom of the motor assembly.
  6. Parrot AR.Drone 2.0 Motor Replacement: 6 단계, 이미지 1/1
    • Remove the three 5mm screws on the top of the motor assembly with a PH00 bit.
  7. Parrot AR.Drone 2.0 Motor Replacement: 7 단계, 이미지 1/1
    • Remove the three 5mm screws on the bottom again using a PH00 bit.
    • The three screws from the top are different from the three screws on the bottom.
  8. Parrot AR.Drone 2.0 Motor Replacement: 8 단계, 이미지 1/2 Parrot AR.Drone 2.0 Motor Replacement: 8 단계, 이미지 2/2
    • Carefully wiggle out the motor assembly out of the arm.
결론
다른 5명이 해당 안내서를 완성하였습니다.
David Hoyt
회원 가입일: 04/09/10
4,023 평판
안내서 43개 작성하였습니다
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G89
4 회원들
안내서 63개 작성하였습니다
댓글 2개
are the motors different on each side?
dbksoft - 답글
I need to know this also. replaced cross.member but did not put motors in original spots now my drone goes crazy and erratic
Steven Maloney -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 14
전체 시간: 5,684
