소개
How to replace a damaged motor. Before beginning, check the position of the 4 different propellers, type "A" or "C".
Step 1 : Remove the propeller, shaft & gear
Step 2 : Remove the damaged motor screws
Step 3 : Remove the damaged motor
Step 4 : Mount the new motor
Step 5 : Fix the new motor screws
Final step : Fix the propeller, shaft & gear
필요한 것
동영상 지침
거의 끝나갑니다!
결론
댓글 한 개
Is the Parrot AR.Drone1.0 Motor compatible with Parrot AR.Drone2.0 motor ? thanks
herrydianto - 답글
