주요 콘텐츠로 건너뛰기
Parrot Bebop Drone GPS Board Replacement
필요한 것
  1. Parrot Bebop Drone GPS Board Replacement, Battery: 1 단계, 이미지 1/2 Parrot Bebop Drone GPS Board Replacement, Battery: 1 단계, 이미지 2/2
    • Begin by removing the velcro strap around the battery.
  2. Parrot Bebop Drone GPS Board Replacement: 2 단계, 이미지 1/2 Parrot Bebop Drone GPS Board Replacement: 2 단계, 이미지 2/2
    • While holding onto the nose, gently pull the battery away from the nose.
  3. Parrot Bebop Drone GPS Board Replacement: 3 단계, 이미지 1/3 Parrot Bebop Drone GPS Board Replacement: 3 단계, 이미지 2/3 Parrot Bebop Drone GPS Board Replacement: 3 단계, 이미지 3/3
    • Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector.
  4. Parrot Bebop Drone GPS Board Replacement, Styrofoam Nose: 4 단계, 이미지 1/2 Parrot Bebop Drone GPS Board Replacement, Styrofoam Nose: 4 단계, 이미지 2/2
    • Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
  5. Parrot Bebop Drone GPS Board Replacement: 5 단계, 이미지 1/1
    • Take the metal spudger, to remove the double stick tape from the foam.
  6. Parrot Bebop Drone GPS Board Replacement: 6 단계, 이미지 1/1
    • Remove the styrofoam nose from over the drone's camera by sliding it towards the front of the drone at an angle.
  7. Parrot Bebop Drone GPS Board Replacement, GPS Board: 7 단계, 이미지 1/1
    • Remove the cable from the top of the GPS module.
  8. Parrot Bebop Drone GPS Board Replacement: 8 단계, 이미지 1/2 Parrot Bebop Drone GPS Board Replacement: 8 단계, 이미지 2/2
    • Remove the two 6mm T5 torx screws holding the GPS module. There is one screw on each side.
    • Remove the 4mm T5 Screw holding the GPS Module.
  9. Parrot Bebop Drone GPS Board Replacement: 9 단계, 이미지 1/1
    • Remove the GPS board by lifting it off of the metal frame.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Austin
회원 가입일: 02/02/17
185 평판
안내서 1개 작성함
UW Tacoma, Team 1-3, Rose Winter 2017 UW Tacoma, Team 1-3, Rose Winter 2017 회원
UWT-ROSE-W17S1G3
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
With voice driving directions maps <a href="https://play.google.com/store/apps/detai...
">GPS Voice Nevigation with speed</a> limits with speaking ,user can get accurate gps coordinates for car GPS navigation.In gps driving guide 2019 users can listen to voice input for voice navigation which gives out all of the audio instructions for direction gps towards destination point on the maps
Albert - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 2,653
