소개
This guide will show the steps needed to remove the GPS Module. In order to remove the GPS Module, the nose will have to be removed first. Removing the GPS Module will require disconnecting the wire connections on it.
필요한 것
Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
With voice driving directions maps <a href="https://play.google.com/store/apps/detai...
">GPS Voice Nevigation with speed</a> limits with speaking ,user can get accurate gps coordinates for car GPS navigation.In gps driving guide 2019 users can listen to voice input for voice navigation which gives out all of the audio instructions for direction gps towards destination point on the maps
