주요 콘텐츠로 건너뛰기
Parrot Bebop Drone Propeller Replacement
  1. Parrot Bebop Drone Propeller Replacement, Propeller: 1 단계, 이미지 1/3 Parrot Bebop Drone Propeller Replacement, Propeller: 1 단계, 이미지 2/3 Parrot Bebop Drone Propeller Replacement, Propeller: 1 단계, 이미지 3/3
    • Using the propeller removal tool (included with the Parrot Bebop Drone), line up the holes with the protruding screws.
  2. Parrot Bebop Drone Propeller Replacement: 2 단계, 이미지 1/2 Parrot Bebop Drone Propeller Replacement: 2 단계, 이미지 2/2
    • While holding the propeller in place, rotate the tool counterclockwise until the screws are aligned with the holes on the propeller.
  3. Parrot Bebop Drone Propeller Replacement: 3 단계, 이미지 1/1
    • While gently pushing down on the arm of which the propeller is attached, pull the propeller up off the motor.
  4. Parrot Bebop Drone Propeller Replacement: 4 단계, 이미지 1/3 Parrot Bebop Drone Propeller Replacement: 4 단계, 이미지 2/3 Parrot Bebop Drone Propeller Replacement: 4 단계, 이미지 3/3
    • When putting the propellers back on, the red propellers go up front and the black ones go on the back.
    • The motors with the protruding axles (front right and rear left) have the propeller with the hole in the middle while the motors without the protruding axles (front left and rear right) have the propellers without the hole in the middle.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nazar Savchuk
회원 가입일: 01/25/17
303 평판
안내서 2개 작성하였습니다
UW Tacoma, Team 1-3, Rose Winter 2017 UW Tacoma, Team 1-3, Rose Winter 2017 회원
UWT-ROSE-W17S1G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 19
전체 시간: 2,206
