이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
While holding onto the nose, gently pull the battery away from the nose.
Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector.
Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
Remove the styrofoam nose from over the drone's camera by sliding it towards the front of the drone at an angle.
Disconnect the two connectors that are attached to the front of the motherboard by gently pulling on the three wires.
Remove the four 5mm torx T5 screws on the bottom of the drone with a Torx Screwdriver.
Lightly pull up using the plastic opening tool to remove the back cover.
Using a small pair of tweezers remove the two antenna wires attached to the motherboard.
Using both hands gently pull the two pieces of the frame apart until you can see the connectors under the frame attached to the motherboard.
Remove both of the connectors from the motherboard. There is one connector on each side.
Remove the four rubber shock absorbers by squeezing and twisting them while also pulling up.
