소개
This guide will show the steps needed to remove the EPP (Expanded Polypropylene) or Styrofoam Nose. The Styrofoam nose protects the motherboard and the GPS Module. In order to remove the Nose, the battery will have to be removed first.
필요한 것
Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
거의 끝나갑니다!
To reassemble your device, follow these intructions in reverse order
결론
다른 2명이 해당 안내서를 완성하였습니다.
