소개
Bring back to life your Parrot FLYPAD with a brand new battery.
This guide will assist you to correctly dismantle the controller, so that you may easily replace the battery. To prevent any loss of screws, it is important to utilize a magnetic mat placed under the controller.
필요한 것
Use a T6 screwdriver to remove the six screws from the back of the controller: four 0.9 mm screws and two 0.1 mm screws.
다른 한 분이 해당 안내서를 완성하였습니다.
