주요 콘텐츠로 건너뛰기
Parrot Hydrofoil Orak Battery Replacement
필요한 것
  1. Parrot Hydrofoil Orak Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Orient the device so that the front of the boat chasis is facing to your right.
  2. Parrot Hydrofoil Orak Battery Replacement: 2 단계, 이미지 1/3 Parrot Hydrofoil Orak Battery Replacement: 2 단계, 이미지 2/3 Parrot Hydrofoil Orak Battery Replacement: 2 단계, 이미지 3/3
    • Use your pointer finger on one tab, your middle finger on the other, and your thumb on the bottom to pry the tabs away and lift the drone out of the holder.
  3. Parrot Hydrofoil Orak Battery Replacement: 3 단계, 이미지 1/2 Parrot Hydrofoil Orak Battery Replacement: 3 단계, 이미지 2/2
    • Insert your plastic opening tool in between the tab with the arrow on it and the battery below it.
    • Pry the tool upwards to disengage the battery.
    • You can disengage the battery with your finger rather than an opening tool, although it takes quite a bit of force and you may need strong nails.
  4. Parrot Hydrofoil Orak Battery Replacement: 4 단계, 이미지 1/1
    • Pull the battery fully out using your fingers.
결론
Matt Sterling
회원 가입일: 10/06/16
183 평판
안내서 1개 작성함
Cal Poly, Team 20-2, Livingston Fall 2016 Cal Poly, Team 20-2, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S20G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 484
