주요 콘텐츠로 건너뛰기
Parrot Hydrofoil Orak Lever Arm Replacement
필요한 것
  1. Parrot Hydrofoil Orak Lever Arm Replacement, Rudder: 1 단계, 이미지 1/1
    • Place the boat so that the front faces to the right.
  2. Parrot Hydrofoil Orak Lever Arm Replacement: 2 단계, 이미지 1/2 Parrot Hydrofoil Orak Lever Arm Replacement: 2 단계, 이미지 2/2
    • Remove the far left 1cm screw using a T8 screwdriver.
  3. Parrot Hydrofoil Orak Lever Arm Replacement: 3 단계, 이미지 1/1
    • Remove the rudder.
  4. Parrot Hydrofoil Orak Lever Arm Replacement, Lever Arm: 4 단계, 이미지 1/3 Parrot Hydrofoil Orak Lever Arm Replacement, Lever Arm: 4 단계, 이미지 2/3 Parrot Hydrofoil Orak Lever Arm Replacement, Lever Arm: 4 단계, 이미지 3/3
    • Remove the four remaining 1cm screws with the T8 screw driver.
  5. Parrot Hydrofoil Orak Lever Arm Replacement: 5 단계, 이미지 1/1
    • Lift up on the plastic piece that is securing the lever arm.
  6. Parrot Hydrofoil Orak Lever Arm Replacement: 6 단계, 이미지 1/2 Parrot Hydrofoil Orak Lever Arm Replacement: 6 단계, 이미지 2/2
    • Flip the plastic part upside down to reveal where the lever arm sits.
  7. Parrot Hydrofoil Orak Lever Arm Replacement: 7 단계, 이미지 1/3 Parrot Hydrofoil Orak Lever Arm Replacement: 7 단계, 이미지 2/3 Parrot Hydrofoil Orak Lever Arm Replacement: 7 단계, 이미지 3/3
    • Lift the lever arm from the slot it is in and slide off of the end of the plastic piece that was holding it to the boat.
결론
Justin Connerly
회원 가입일: 10/06/16
273 평판
안내서 2개 작성하였습니다
Cal Poly, Team 20-2, Livingston Fall 2016 Cal Poly, Team 20-2, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S20G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 124
