주요 콘텐츠로 건너뛰기
Parrot Skycontroller 2 Joystick Replacement
필요한 것
  1. Parrot Skycontroller 2 Joystick Replacement, Battery: 1 단계, 이미지 3개 중 1개 Parrot Skycontroller 2 Joystick Replacement, Battery: 1 단계, 이미지 3개 중 2개 Parrot Skycontroller 2 Joystick Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Flip your controller face down.
  2. Parrot Skycontroller 2 Joystick Replacement: 2 단계, 이미지 1개 중 1개
    • Remove one 9mm screw using a #4 flathead screwdriver.
  3. Parrot Skycontroller 2 Joystick Replacement: 3 단계, 이미지 3개 중 1개 Parrot Skycontroller 2 Joystick Replacement: 3 단계, 이미지 3개 중 2개 Parrot Skycontroller 2 Joystick Replacement: 3 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
    • Remove the cover by pulling up and out.
  4. Parrot Skycontroller 2 Joystick Replacement: 4 단계, 이미지 3개 중 1개 Parrot Skycontroller 2 Joystick Replacement: 4 단계, 이미지 3개 중 2개 Parrot Skycontroller 2 Joystick Replacement: 4 단계, 이미지 3개 중 3개
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
  5. Parrot Skycontroller 2 Joystick Replacement: 5 단계, 이미지 2개 중 1개 Parrot Skycontroller 2 Joystick Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the battery from its brackets by pulling up on the ends of the battery.
  6. Parrot Skycontroller 2 Joystick Replacement, Joystick: 6 단계, 이미지 1개 중 1개
    • Remove the seven black 11mm screws using the Torx TR6 screwdriver
    • There is a hidden screw located behind the sticker in the battery compartment.
    • Pull back the sticker with your finger nail and remove the one black 11mm screws using the Torx TR6 screwdriver
  7. Parrot Skycontroller 2 Joystick Replacement: 7 단계, 이미지 3개 중 1개 Parrot Skycontroller 2 Joystick Replacement: 7 단계, 이미지 3개 중 2개 Parrot Skycontroller 2 Joystick Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the seven silver 4mm screws from around the edge of the top plate with the Torx TR6 Screwdriver.
    • The opposite side to the third picture has a screw located on each side of the USB port.
  8. Parrot Skycontroller 2 Joystick Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the battery compartment plate by pulling up and out.
  9. Parrot Skycontroller 2 Joystick Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the top plate by pushing out on the corners with your hand.
    • Be careful to not pull too hard on the cable.
  10. Parrot Skycontroller 2 Joystick Replacement: 10 단계, 이미지 2개 중 1개 Parrot Skycontroller 2 Joystick Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the face plate by pulling up and out.
    • Buttons will fall out when this plate is removed.
  11. Parrot Skycontroller 2 Joystick Replacement: 11 단계, 이미지 3개 중 1개 Parrot Skycontroller 2 Joystick Replacement: 11 단계, 이미지 3개 중 2개 Parrot Skycontroller 2 Joystick Replacement: 11 단계, 이미지 3개 중 3개
    • Firmly grasp the end of either joystick.
    • Pull the joystick up and out while grasping the other side of the controller.
    • Once both joysticks have been removed, this is what it should look like.
    • Some force may be needed to remove the joysticks.
    • Repeat this process for the other side as well.
결론
작성자
3다른 기여자 명과 함께
Alec Diaz
회원 가입일: 01/26/20
136 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 544
