소개
The telescoping handle on your Patagonia Transport Roller Luggage is designed to withstand years of hard use. But sometimes the handle becomes jammed or stuck and needs to be replaced to operate properly. Fortunately, installing a replacement handle is quick and easy.
For replacement parts or further assistance, contact Patagonia Customer Service.
This guide is specifically for the Patagonia Transport Roller, Style Number 4905. If you aren't sure which bag you have, here's a guide that can help you identify the style number of Patagonia products.
도구
부품
지정된 부품이 없습니다.
Lay your Transport Roller on its back on a table.
Unzip the main compartment.
To reassemble your luggage, follow these instructions starting with Step 9. You’ll be working backwards now from that point in the guide, following the steps in reverse order.
