이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Lay your Transport Roller on its back on a table.
Unzip the main compartment.
Unzip the the zipper in the gray inner lining of the bag, opening the lining as you go.
Remove the two Phillips #1 screws from the retaining bracket at the bottom of the bag.
Remove the five Phillips #1 screws from the retaining bracket at the top of the bag.
Using your thumb, depress the button on the telescoping handle.
With the button depressed, extend the handle by pulling away from the bag.
Turn the bag over so that the back is facing up.
Remove the telescoping handle assembly by pulling it out of the top of the bag.
If you are having trouble with your handle, check the pins inside the bag.
If either pin is not retracting when the button on the handle is depressed, push the pin into the hole using your finger or another thin object such as a pencil or screwdriver.
