주요 콘텐츠로 건너뛰기
Patch your Patagonia Nano Puff ® Jacket with Repair Tape
필요한 것
  1. Patch your Patagonia Nano Puff ® Jacket with Repair Tape, Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 1 단계, 이미지 1/1
    • Inspect the damage on your jacket. Clip any dangling threads or fabric using small scissors.
  2. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 2 단계, 이미지 1/3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 2 단계, 이미지 2/3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 2 단계, 이미지 3/3
    • Grab your repair tape.
    • Flip the repair tape to the back side.
    • Using a permanent marker, draw an oval slightly larger than the hole.
    • If you have a wide hole, you can use a rectangle, but be sure to round the edges. Rounding the edges prevents the corners from getting caught and peeling up.
  3. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 3 단계, 이미지 1/2 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 3 단계, 이미지 2/2
    • Cut out your shape using scissors.
  4. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 4 단계, 이미지 1/3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 4 단계, 이미지 2/3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 4 단계, 이미지 3/3
    • Using your fingernail, or a pin, peel the backing off the tenacious tape, so that you only have the clear sticky layer.
    • Be sure not to touch the sticky side of the tape as this will gum up the tape and it won’t stick well.
  5. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 5 단계, 이미지 1/2 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 5 단계, 이미지 2/2
    • Lay the tape over the hole and press the tape down with your finger.
  6. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 6 단계, 이미지 1/2 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 6 단계, 이미지 2/2
    • Use a fingernail or spudger to work out all of the air bubbles under the tape. Continue rubbing the tape until it is well-adhered.
결승점
다른 9명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
88,229 평판
안내서 132개 작성하였습니다
iFixit iFixit 회원
Community
141 회원들
안내서 17,707개 작성하였습니다
댓글 한 개
I followed this tutorial and used Tenacious tape by Gear Aid because it claims to not leave a residue behind if removed. That was a bad idea. I am now ready to upgrade this patch to a sewn one and removing the tape is absolutely leaving behind a residue. Really annoyed right now.
Ling Wang - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 142
전체 시간: 43,106
