주요 콘텐츠로 건너뛰기
Patching a 125 2 stroke fuel tank
필요한 것
  1. Patching a 125 2 stroke fuel tank, Patching a 125 2 stroke fuel tank: 1 단계, 이미지 1개 중 1개
    • First, you will need to sand down the rough edges around the hole in fuel tank.
    • Make sure the hole in the fuel tank and its surrounding is as smooth as possible.
  2. Patching a 125 2 stroke fuel tank: 2 단계, 이미지 1개 중 1개
    • Once the hole is smooth. Apply fuel patch with q-tip over hole and the surrounding edges.
  3. Patching a 125 2 stroke fuel tank: 3 단계, 이미지 1개 중 1개
    • Make sure that the ointment is spread thickly over the hole.
  4. Patching a 125 2 stroke fuel tank: 4 단계, 이미지 1개 중 1개
    • Avoid having air pockets in the ointment. Air pockets may make the patch less effective or not seal at all.
    • Once the ointment is spread over smoothly, you will need to rub the edges out so there is no edge that can be caught on something.
  5. Patching a 125 2 stroke fuel tank: 6 단계, 이미지 1개 중 1개
    • Let the patch dry over.
    • Try not to touch patch until completely dry. This may take a couple hours.
  6. Patching a 125 2 stroke fuel tank: 7 단계, 이미지 1개 중 1개
    • Next, you will need to check the patch after completely dry. Make sure there is no bubbles or edges where there could be another potential leak.
    • Once patch is dry put fuel in the tank.
    • When tank is full check to see if there are any leaks in the patch. Leaks consist of fuel dripping or even air leak from patch.
    • If there are leaks scrape off patch and repeat process.
  7. Patching a 125 2 stroke fuel tank: 11 단계, 이미지 1개 중 1개
    • When there are no leaks start riding. Your tank is now patched. Check up on patch after ride to make sure it is still sealed.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andrew
회원 가입일: 02/17/15
1,387 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 57
전체 시간: 1,843
