주요 콘텐츠로 건너뛰기
Patching a Bicycle Tire Inner Tube
필요한 것
  1. Patching a Bicycle Tire Inner Tube, Rear Wheel: 1 단계, 이미지 2개 중 1개 Patching a Bicycle Tire Inner Tube, Rear Wheel: 1 단계, 이미지 2개 중 2개
    • Flip the quick release lever on the wheel.
  2. Patching a Bicycle Tire Inner Tube: 2 단계, 이미지 1개 중 1개
    • Squeeze the brake arms together and lift the brake cable from the caliper arms.
  3. Patching a Bicycle Tire Inner Tube: 3 단계, 이미지 1개 중 1개
    • Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
  4. Patching a Bicycle Tire Inner Tube, Inner Tube: 4 단계, 이미지 1개 중 1개
    • Press the valve core while applying pressure to the tire to deflate the tire.
  5. Patching a Bicycle Tire Inner Tube: 5 단계, 이미지 2개 중 1개 Patching a Bicycle Tire Inner Tube: 5 단계, 이미지 2개 중 2개
    • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
    • Slide the lever around the circumference of the wheel to completely remove the tire.
    • Alternatively, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches away. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third. Work along the rim until the tire pops off.
  6. Patching a Bicycle Tire Inner Tube: 6 단계, 이미지 1개 중 1개
    • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
  7. Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: 7 단계, 이미지 1개 중 1개
  8. Patching a Bicycle Tire Inner Tube: 8 단계, 이미지 2개 중 1개 Patching a Bicycle Tire Inner Tube: 8 단계, 이미지 2개 중 2개
  9. Patching a Bicycle Tire Inner Tube: 9 단계, 이미지 1개 중 1개
    • Remove the tube by pushing the valve through the hole in the rim and pulling out completely.
  10. Patching a Bicycle Tire Inner Tube: 10 단계, 이미지 2개 중 1개 Patching a Bicycle Tire Inner Tube: 10 단계, 이미지 2개 중 2개
    • Locate the leak by first over inflating the tire.
    • Place the tire under water and look for bubbles to find the leak.
  11. Patching a Bicycle Tire Inner Tube: 11 단계, 이미지 1개 중 1개
    • Mark the hole with a marker, and completely deflate the tire.
  12. Patching a Bicycle Tire Inner Tube: 12 단계, 이미지 1개 중 1개
    • Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
  13. Patching a Bicycle Tire Inner Tube: 13 단계, 이미지 1개 중 1개
    • Clean the area near the hole with soap and water, then dry it thoroughly.
    • Rough up the area around the hole with an abrasive surface such as sand paper until the area around the leak loses its shine.
  14. Patching a Bicycle Tire Inner Tube: 14 단계, 이미지 1개 중 1개
    • Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
  15. Patching a Bicycle Tire Inner Tube: 15 단계, 이미지 1개 중 1개
    • Apply the patch to the area.
  16. Patching a Bicycle Tire Inner Tube: 16 단계, 이미지 1개 중 1개
    • Apply pressure to the patch until the rubber cement is dry.
결론
To reassemble your wheel, follow these instructions in reverse order starting at step three.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Travis Tonder
회원 가입일: 10/05/10
3,210 평판
안내서 4개를 작성함
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010 회원
CPSU-MANESS-F10S5G13
4 회원들
안내서 17개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 4,155
