소개
You will be taking the wheel off of your bike, removing the tire from the wheel, and patching the hole.
Notes:
- Make sure that the wheel is fully deflated throughout the process, except for finding the hole.
- When applying the rubber cement to the hole, the thinner the layer the better, for faster drying.
필요한 것
Press the valve core while applying pressure to the tire to deflate the tire.
거의 끝나갑니다!
To reassemble your wheel, follow these instructions in reverse order starting at step three.
결론
다른 6명이 해당 안내서를 완성하였습니다.
