소개
This guide will help you replace your worn out and beaten down bass strings. This is a simple yet useful guide that will give you a brief explanation on how to go about restringing a bass the correct way without confusion. The method will be similar for other, non-Peavey basses so this guide will be useful for any bass guitar. Hope this helps anyone that needs it and rock on!
필요한 것
Spin the pegs in the direction which loosens the string. Either unwind the string all the way and pull it out, or cut the string after loosening it a little.
Starting with the thickest string (E string), feed the string through the left-most hole at the base of the bridge (pictured left).
Repeat what you did with the E string with next thickest string (A string).
Repeat again for the next thinnest (D string), and again for the thinnest string (G string).
Starting with the E string, make sure the string is in line with the correct notch on the nut.
Locate the hole in the guide and feed the string through the hole so it sticks out about one centimeter.
Rotate the tuning peg so that the string rotates counter-clockwise until the string is taut.
Repeat for the other 3 strings.
In order to get your bass sounding brand new again follow these steps and youll get a wonderful result
다른 한 분이 해당 안내서를 완성하였습니다.
