소개
Would you like to switch out the watch band on your Pebble Steel from leather to metal or vice versa? This guide will show you how.
필요한 것
Place the watch on its side to expose the side pins.
Use a 1.5 mm flathead screwdriver to unscrew the pin that is holding the band.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
One of my Pebble Steel pins comes out just as expected, but the other just spins, and doesn’t come out. Any ideas?
