주요 콘텐츠로 건너뛰기
Pebble Time Battery Replacement
필요한 것
  1. Pebble Time Battery Replacement, Screen Cover: 1 단계, 이미지 1개 중 1개
    • Lay the watch flat on your workstation.
  2. Pebble Time Battery Replacement: 2 단계, 이미지 2개 중 1개 Pebble Time Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Battery Replacement, Screen: 5 단계, 이미지 1개 중 1개
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Battery Replacement: 7 단계, 이미지 3개 중 1개 Pebble Time Battery Replacement: 7 단계, 이미지 3개 중 2개 Pebble Time Battery Replacement: 7 단계, 이미지 3개 중 3개
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
  8. Pebble Time Battery Replacement, Circuit Board: 8 단계, 이미지 1개 중 1개
    • Keep the watch flat on your workstation.
  9. Pebble Time Battery Replacement: 9 단계, 이미지 1개 중 1개
    • Locate the three screws on the circuit board.
    • Remove using the J000 Philips head screwdriver.
  10. Pebble Time Battery Replacement: 10 단계, 이미지 3개 중 1개 Pebble Time Battery Replacement: 10 단계, 이미지 3개 중 2개 Pebble Time Battery Replacement: 10 단계, 이미지 3개 중 3개
    • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
    • Move apart the connector to expose the fourth screw.
  11. Pebble Time Battery Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
  12. Pebble Time Battery Replacement: 12 단계, 이미지 2개 중 1개 Pebble Time Battery Replacement: 12 단계, 이미지 2개 중 2개
    • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
    • Remove the circuit board from the case.
  13. Pebble Time Battery Replacement, Battery: 13 단계, 이미지 1개 중 1개
    • After removing the circuit board, the battery is located in the middle of the case.
  14. Pebble Time Battery Replacement: 14 단계, 이미지 2개 중 1개 Pebble Time Battery Replacement: 14 단계, 이미지 2개 중 2개
    • Locate the battery connector on the left side of the case.
    • Carefully disconnect the wire using a metal spudger.
  15. Pebble Time Battery Replacement: 15 단계, 이미지 2개 중 1개 Pebble Time Battery Replacement: 15 단계, 이미지 2개 중 2개
    • After disconnecting the battery use the plastic opening tool to lift the battery off of the case.
    • The battery might be glued to the case.
결론
다른 33명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nicolas Hempe
회원 가입일: 02/15/17
1,468 평판
안내서 5개를 작성함
USF Tampa, Team 1-3, Sullivan Spring 2017 USF Tampa, Team 1-3, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S1G3
4 회원들
안내서 10개를 작성함
12가이드 댓글
Where did you purchase the replacement battery?
Dimas Caparros - 답글
Got mine on Amazon
kwojdak -
What is everyone using for sticky tape to hold the bezel/crystal on that will ensure the pebble is still waterproof?
Shannon Oswald - 답글
Attempted this using RTV Silicon, and it is %#*@ difficult to not get it EVERYWHERE! I got some on my LCD, now I’m looking for another Pebble. Just use a little superglue on the outside and don’t figure on it being waterproof anymore - I guess.
Shannon Oswald - 답글
There’s a lot of replacement battery on internet. Just search “150mAh P11G7T-01-S01”.
Xie Yanbo - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 61
지난 30일: 347
전체 시간: 25,761
