주요 콘텐츠로 건너뛰기
Pebble Time Round E-Paper Display Replacement
필요한 것
  1. Pebble Time Round E-Paper Display Replacement, Glass Screen Protector: 1 단계, 이미지 1개 중 1개
    • Wedge an opening tool between the case of the watch, and the glass screen bezel.
    • Pry the screen bezel away from the device.
    • If you have a difficult time getting the front bezel to separate from the case, try warming the watch up with a hair dryer.
    • There are three very tiny springs that are compressed between holes in the case and the front bezel. They can pop out once the bezel is removed, so don't lose them! Remove them and put them somewhere safe once the bezel is removed.
  2. Pebble Time Round E-Paper Display Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the screen protector away from the device, breaking glue sealant.
    • Separate the screen protector from the screen.
    • To re-seal the glass protector's glue, simply heat the glue.
  3. Pebble Time Round E-Paper Display Replacement, E-Paper Display: 3 단계, 이미지 1개 중 1개
    • Insert a prying tool between the bezel ring and the e-paper screen. Move the tool around the circumference of the ring until it separates from the e-paper screen.
  4. Pebble Time Round E-Paper Display Replacement: 4 단계, 이미지 2개 중 1개 Pebble Time Round E-Paper Display Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Slightly lift the screen and you will see a yellow cable that connects to the motherboard.
    • Use a pair of tweezers to carefully pull the cable up from the motherboard to disconnect it.
  5. Pebble Time Round E-Paper Display Replacement: 5 단계, 이미지 1개 중 1개
    • Use tweezers to disconnect the small yellow wire from the top of the e-paper screen.
    • The wire is connected with a bit of glue, so it will come off with ease.
결론
작성자
2다른 기여자 명과 함께
Jonathan Carreiro
회원 가입일: 10/30/21
219 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021 회원
UMASSD-GULBRANDSEN-F21S4G5
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 750
