주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pebble Time Round Glass Screen Protector Replacement
필요한 것
  1. Pebble Time Round Glass Screen Protector Replacement, Glass Screen Protector: 1 단계, 이미지 1개 중 1개
    • Wedge an opening tool between the case of the watch, and the glass screen bezel.
    • Pry the screen bezel away from the device.
    • If you have a difficult time getting the front bezel to separate from the case, try warming the watch up with a hair dryer.
    • There are three very tiny springs that are compressed between holes in the case and the front bezel. They can pop out once the bezel is removed, so don't lose them! Remove them and put them somewhere safe once the bezel is removed.
  2. Pebble Time Round Glass Screen Protector Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the screen protector away from the device, breaking glue sealant.
    • Separate the screen protector from the screen.
    • To re-seal the glass protector's glue, simply heat the glue.
결론
작성자
4다른 기여자 명과 함께
Kyle
회원 가입일: 11/01/21
85 평판
안내서 1개를 작성함
UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021 회원
UMASSD-GULBRANDSEN-F21S4G5
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 39
전체 시간: 651
