주요 콘텐츠로 건너뛰기
Pebble Time Screen Cover Replacement
필요한 것
  1. Pebble Time Screen Cover Replacement, Screen Cover: 1 단계, 이미지 1개 중 1개
    • Lay the watch flat on your workstation.
  2. Pebble Time Screen Cover Replacement: 2 단계, 이미지 2개 중 1개 Pebble Time Screen Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Screen Cover Replacement: 3 단계, 이미지 1개 중 1개
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Screen Cover Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully, pull apart the cover with the plastic opening tool.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Nicolas Hempe
회원 가입일: 02/15/17
1,468 평판
안내서 5개를 작성함
USF Tampa, Team 1-3, Sullivan Spring 2017 USF Tampa, Team 1-3, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S1G3
4 회원들
안내서 10개를 작성함
5가이드 댓글
What does one use to hold the screen on and reseal for waterproofing?
Shannon Oswald - 답글
Using RTV silicon is problematic, I got some on my LCD and now I’m looking for a replacement Pebble.
Shannon Oswald - 답글
HI I scratched my Crystal on my Pebble Time watch. Can the Crystal be buffed to get the scratch out??
Janice Pruett - 답글
This is a brand new Pebble Time watch!!
Janice Pruett - 답글
CONCLUSION
To reassemble your device, follow these instructions in reverse order.”
Yeah, what about an adhesive or sealant? Best practice for doing so?
Adam MacDonald - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 24
전체 시간: 1,911
