주요 콘텐츠로 건너뛰기
Pebble Time Screen Replacement
필요한 것
  1. Pebble Time Screen Replacement, Screen Cover: 1 단계, 이미지 1개 중 1개
    • Lay the watch flat on your workstation.
  2. Pebble Time Screen Replacement: 2 단계, 이미지 2개 중 1개 Pebble Time Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Screen Replacement, Screen: 5 단계, 이미지 1개 중 1개
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Screen Replacement: 7 단계, 이미지 3개 중 1개 Pebble Time Screen Replacement: 7 단계, 이미지 3개 중 2개 Pebble Time Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Saud Al-Malki
회원 가입일: 02/19/17
110 평판
안내서 1개를 작성함
USF Tampa, Team 1-3, Sullivan Spring 2017 USF Tampa, Team 1-3, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S1G3
4 회원들
안내서 10개를 작성함
3가이드 댓글
Where can I buy the display replacement?
ulises - 답글
Hello Ulises,
Based off of my search, I couldn’t find any place where you can buy a display replacement. I advise you to look on Ebay, Amazon, or you can contact Pebble Time for more information at https://www.pebble.com or +18882245820. If none of this works out for you, you might want to check local tech repair shops.
Hope this helps.
Saud Al-Malki - 답글
Hola.
¿I have a question ?
What adhesive What adhesive should I buy to stick it again after placing the screen?
bladimir gonzalez matos - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 48
전체 시간: 3,745
