주요 콘텐츠로 건너뛰기
Pebble Time Steel - reparing of a non working button
필요한 것
  1. Pebble Time Steel - reparing of a non working button, Repairing of a non working button: 1 단계, 이미지 1/2 Pebble Time Steel - reparing of a non working button, Repairing of a non working button: 1 단계, 이미지 2/2
    • With opening picks we start to open the watch by lifting up the display bottom from left (about seven o'clock) in counterclockwise direction. In the left side there is a flexband that has to be disconnected.
  2. Pebble Time Steel - reparing of a non working button: 2 단계, 이미지 1/1
    • Three screws are removed.
  3. Pebble Time Steel - reparing of a non working button: 3 단계, 이미지 1/1
    • down on the left, a Flexband is carefully folded up and loosened. Below it, another screw is visible.
    • Remove this screw.
  4. Pebble Time Steel - reparing of a non working button: 4 단계, 이미지 1/2 Pebble Time Steel - reparing of a non working button: 4 단계, 이미지 2/2
    • Then the board can be removed carefully.
    • If you look closely at the keys, you can see that the defective key no longer carries rubber dabs.
    • With a needle, the smallest drops of superglue are dripped into place of the missing rubber.
    • Now put everything together in reverse order. Remove the sealant before applying the display and stick it around with a new Tesa 61395 Tape 1mm.
    • Then insert the display and press down.
결론
Repeat the steps in reverse order to reassemble your device.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Vasco Dunker
회원 가입일: 12/02/18
256 평판
안내서 1개 작성함
댓글 2개
thanks , I managed to fix my pebble time steel with this guide. it may not be waterproof but at least my buttons no longer stick…
I think the reason it failed was because some water already got inside… could get my pebble starting anymore
Kah Kin Yau - 답글
Works great! Thanks for the guide :D
I would've liked to add an additional step, but it doesn't appear that I can - one other thing that I've found can cause buttons to stick is in the inside of the casing, on each button there's a little circlip that sits in a detent on the pokey bit - if this comes out of its detent, then the button can become quite hard to press and hard to work with. Unfortunately I can't post pictures here, but there's a picture in this Imgur thread of what I'm talking about: https://imgur.com/gallery/V4SUvbz
Aadi Bhamidipati - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 32
전체 시간: 1,685
