주요 콘텐츠로 건너뛰기
Penguin FZ-8 28” Tower Fan Blade Replacement
필요한 것
  1. Penguin FZ-8 28” Tower Fan Blade Replacement, Fan Blade: 1 단계, 이미지 1/1
    • Flip the fan onto its side so that you can access the base of the fan.
    • Remove the single 11 mm screw using a Phillips #1 screwdriver.
  2. Penguin FZ-8 28” Tower Fan Blade Replacement: 2 단계, 이미지 1/3 Penguin FZ-8 28” Tower Fan Blade Replacement: 2 단계, 이미지 2/3 Penguin FZ-8 28” Tower Fan Blade Replacement: 2 단계, 이미지 3/3
    • Rotate the base of the fan counter-clockwise to detach it from the rest of the fan. The base can be separated into two parts.
  3. Penguin FZ-8 28” Tower Fan Blade Replacement: 3 단계, 이미지 1/2 Penguin FZ-8 28” Tower Fan Blade Replacement: 3 단계, 이미지 2/2
    • Remove four 5 mm screws from the sides of the base of the fan using the Phillips #1 screwdriver.
  4. Penguin FZ-8 28” Tower Fan Blade Replacement: 4 단계, 이미지 1/2 Penguin FZ-8 28” Tower Fan Blade Replacement: 4 단계, 이미지 2/2
    • Remove the two 5 mm screws located on the outside of the case inside the holes using the Phillips #1 screwdriver.
  5. Penguin FZ-8 28” Tower Fan Blade Replacement: 5 단계, 이미지 1/2 Penguin FZ-8 28” Tower Fan Blade Replacement: 5 단계, 이미지 2/2
    • Remove a single 5 mm screw on the outside cover of the fan using the Phillips #1 screwdriver.
    • Gently lift the top cover of the fan halfway to expose the single 5 mm screw. Remove this screw using the same Phillips #1 screwdriver.
  6. Penguin FZ-8 28” Tower Fan Blade Replacement: 6 단계, 이미지 1/2 Penguin FZ-8 28” Tower Fan Blade Replacement: 6 단계, 이미지 2/2
    • Pinch the sides of the case to remove the case from the rest of the fan.
  7. Penguin FZ-8 28” Tower Fan Blade Replacement: 7 단계, 이미지 1/1
    • Remove the single 5 mm screw between the fan blade and the motor using the Phillips #1 screwdriver.
  8. Penguin FZ-8 28” Tower Fan Blade Replacement: 8 단계, 이미지 1/2 Penguin FZ-8 28” Tower Fan Blade Replacement: 8 단계, 이미지 2/2
    • Remove the two 5 mm screws holding the fan blade in place using the Phillips #1 screwdriver.
  9. Penguin FZ-8 28” Tower Fan Blade Replacement: 9 단계, 이미지 1/1
    • Remove the fan blade from the device and clean it off before reassembling your device.
결론
Ethan
회원 가입일: 03/22/21
169 평판
안내서 1개 작성함
UMass Dartmouth, Team S2-G4, Riel Spring 2021 UMass Dartmouth, Team S2-G4, Riel Spring 2021 회원
UMASSD-RIEL-S21S2G4
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 38
전체 시간: 924
