주요 콘텐츠로 건너뛰기
Penn-Plax Cascade 20 Power Filter Impeller Replacement
필요한 것
  1. Penn-Plax Cascade 20 Power Filter Impeller Replacement, Impeller: 1 단계, 이미지 1/1
    • Start by placing filter system on your workstation of choice.
  2. Penn-Plax Cascade 20 Power Filter Impeller Replacement: 2 단계, 이미지 1/3 Penn-Plax Cascade 20 Power Filter Impeller Replacement: 2 단계, 이미지 2/3 Penn-Plax Cascade 20 Power Filter Impeller Replacement: 2 단계, 이미지 3/3
    • Remove all detachable pieces from the filter. This includes the lid, pipe, and filter media.
  3. Penn-Plax Cascade 20 Power Filter Impeller Replacement: 3 단계, 이미지 1/3 Penn-Plax Cascade 20 Power Filter Impeller Replacement: 3 단계, 이미지 2/3 Penn-Plax Cascade 20 Power Filter Impeller Replacement: 3 단계, 이미지 3/3
    • Take your filter and place it upside down.
    • Place your hand on the motor. Grab it firmly and turn it clockwise for a quarter turn. When the turn is complete, it should look like the second picture.
    • Pull the motor up and out from the filter chassis.
    • The motor should be able to be pulled off with ease.
  4. Penn-Plax Cascade 20 Power Filter Impeller Replacement: 4 단계, 이미지 1/3 Penn-Plax Cascade 20 Power Filter Impeller Replacement: 4 단계, 이미지 2/3 Penn-Plax Cascade 20 Power Filter Impeller Replacement: 4 단계, 이미지 3/3
    • Take your index finger and thumb and firmly grip one of the impeller blades.
    • Pull the impeller up and out of the motor shaft.
    • You should feel mild resistance because the impeller is secured via magnet.
  5. Penn-Plax Cascade 20 Power Filter Impeller Replacement: 5 단계, 이미지 1/3 Penn-Plax Cascade 20 Power Filter Impeller Replacement: 5 단계, 이미지 2/3 Penn-Plax Cascade 20 Power Filter Impeller Replacement: 5 단계, 이미지 3/3
    • To install a new impeller, grab it by the fins and place it back into the motor shaft hole.
    • Push the new impeller in and make sure it is connected to the magnetic seal. This can be checked by flipping the motor upside down and seeing if the impeller falls out.
결론
Your Penn-Plax Cascade 20 Power Filter should be up and running again!
다른 한 분이 해당 안내서를 완성하였습니다.
Danny Vo
회원 가입일: 03/06/22
145 평판
안내서 1개 작성함
UM-KIM-S22SM50G2 UM-KIM-S22SM50G2 회원
Community
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 586
