주요 콘텐츠로 건너뛰기
Pentax Optio S4i Front and Back Cover Replacement
필요한 것
  1. Pentax Optio S4i Front and Back Cover Replacement, Front and Back Cover: 1 단계, 이미지 1/2 Pentax Optio S4i Front and Back Cover Replacement, Front and Back Cover: 1 단계, 이미지 2/2
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Pentax Optio S4i Front and Back Cover Replacement: 2 단계, 이미지 1/1
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Pentax Optio S4i Front and Back Cover Replacement: 3 단계, 이미지 1/2 Pentax Optio S4i Front and Back Cover Replacement: 3 단계, 이미지 2/2
    • Carefully pull the back of casing away from the front.
  4. Pentax Optio S4i Front and Back Cover Replacement: 4 단계, 이미지 1/3 Pentax Optio S4i Front and Back Cover Replacement: 4 단계, 이미지 2/3 Pentax Optio S4i Front and Back Cover Replacement: 4 단계, 이미지 3/3
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  5. Pentax Optio S4i Front and Back Cover Replacement: 5 단계, 이미지 1/2 Pentax Optio S4i Front and Back Cover Replacement: 5 단계, 이미지 2/2
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nicole Wong
회원 가입일: 01/30/11
329 평판
안내서 3개 작성하였습니다
Cal Poly, Team 4-29, Regan Winter 2011 Cal Poly, Team 4-29, Regan Winter 2011 회원
CPSU-REGAN-W11S4G29
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 3,230
