소개
Use this guide to remove and replace a damaged battery cover on the Pentax Optio WG-2.
필요한 것
1 단계 Back Case
주의: 1-6 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Remove all four 1 mm JIS #00 screws from the back of the camera.
Lift the cover as you normally would if replacing battery.
Holding the camera with the lens facing away from you and the battery slot upward slide the cover towards the back of the camera.
거의 끝나갑니다!
결론
