주요 콘텐츠로 건너뛰기
Pentax Optio WG-3 GPS Lens Assembly Replacement
필요한 것
  1. Pentax Optio WG-3 GPS Lens Assembly  Replacement, Lens Assembly: 1 단계, 이미지 1/1
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Lens Assembly  Replacement: 2 단계, 이미지 1/1
    • Flip over the camera so the bottom is facing up.
    • Remove the single Phillips #000 screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Lens Assembly  Replacement: 3 단계, 이미지 1/1
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Lens Assembly  Replacement: 4 단계, 이미지 1/1
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Lens Assembly  Replacement: 5 단계, 이미지 1/1
    • Flip the circuitry so that the lens is facing up and the flash component is on your right.
    • Identify the orange ribbon tape surrounding the lens.
  6. Pentax Optio WG-3 GPS Lens Assembly  Replacement: 6 단계, 이미지 1/1
    • There are three 5 mm Phillips #000 screws to be removed on the right side of the lens.
  7. Pentax Optio WG-3 GPS Lens Assembly  Replacement: 7 단계, 이미지 1/1
    • Gently slide the lens piece to the right, remove the tape and take it out.
결론
Garrett Rose
회원 가입일: 03/31/22
373 평판
안내서 2개 작성하였습니다
IUPUI, Team 3-1, Harley Spring 2022 IUPUI, Team 3-1, Harley Spring 2022 회원
IUPUI-HARLEY-S22S3G1
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 196
