주요 콘텐츠로 건너뛰기
Pentax Optio WG-3 GPS Menu Button Replacement
필요한 것
  1. Pentax Optio WG-3 GPS Menu Button Replacement, Menu Button: 1 단계, 이미지 3개 중 1개 Pentax Optio WG-3 GPS Menu Button Replacement, Menu Button: 1 단계, 이미지 3개 중 2개 Pentax Optio WG-3 GPS Menu Button Replacement, Menu Button: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the 6, 5 mm screws, 4 on each corner and 2 on the sides of the device.
    • One of the side screws is hidden under the top lining of the device.The lining is glued down to the device so you will have to peel the lining back using tweezers. After you are finished with your work you will have to use glue or adhesive to re-stick the lining back to the device.
  2. Pentax Optio WG-3 GPS Menu Button Replacement: 2 단계, 이미지 1개 중 1개
    • With the small plastic pry tool lift the back of the camera off carefully.
    • Open the device slowly and be aware of a few flex cables that connect the mother board to the screen. These will have to be carefully disconnected before the top part is removed.
  3. Pentax Optio WG-3 GPS Menu Button Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the 8, 2 mm screws from each corner of the metal button pad cover.
    • Using tweezers remove the metal cover.
    • The smaller Metal square piece on the device.
  4. Pentax Optio WG-3 GPS Menu Button Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the 1, 2 mm screw near the edge of the device.
  5. Pentax Optio WG-3 GPS Menu Button Replacement: 5 단계, 이미지 1개 중 1개
    • Now using tweezers, remove the menu button from its place.
    • After removing the button you can replace the entire component.
결론
작성자
3다른 기여자 명과 함께
Allison Merdian
회원 가입일: 03/05/15
422 평판
안내서 4개를 작성함
Sam Houston State, Team 11-4, Blackburne Winter 2015 Sam Houston State, Team 11-4, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S11G4
2 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 577
