주요 콘텐츠로 건너뛰기
Pentax Optio WG-3 GPS Motherboard Replacement
필요한 것
  1. Pentax Optio WG-3 GPS Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Flip over the camera so the bottom is facing up.
    • Use the Phillips PH0005 again to remove one more 5mm screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • There is a large silver sticker on top of the motherboard, gently remove it off of the motherboard.
  6. Pentax Optio WG-3 GPS Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Gently use the spudger set to lift open the clamps that are holding the orange ribbons down.
    • Pull out the ribbons and remove the motherboard from the body of the camera.
  7. Pentax Optio WG-3 GPS Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the battery on the back of the motherboard.
  8. Pentax Optio WG-3 GPS Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Unscrew and remove one 2 mm Phillips #00 screw to remove the flash component on the top of the circuitry.
  9. Pentax Optio WG-3 GPS Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Remove three 5 mm Phillips #000 screws from the left side of the motherboard.
  10. Pentax Optio WG-3 GPS Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Remove two ribbon cables from the small circuit.
    • Remove the ribbon cable that holds the sensor to the motherboard.
  11. Pentax Optio WG-3 GPS Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • The sensor is ready to be pulled out, carefully remove the sensor.
  12. Pentax Optio WG-3 GPS Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Unscrew and remove three 5 mm screws from the front panel of the battery compartment.
  13. Pentax Optio WG-3 GPS Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    • Pull the black panel away from the front panel.
  14. Pentax Optio WG-3 GPS Motherboard Replacement: 14 단계, 이미지 1개 중 1개
    • At the top of the circuit board there are three soldered dots that need to be unsoldered to remove the back of the battery component from the motherboard.
    • The motherboard can now be pulled and replaced.
결론
작성자
2다른 기여자 명과 함께
Garrett Rose
회원 가입일: 03/31/22
373 평판
안내서 2개를 작성함
IUPUI, Team 3-1, Harley Spring 2022 IUPUI, Team 3-1, Harley Spring 2022 회원
IUPUI-HARLEY-S22S3G1
3 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 423
