주요 콘텐츠로 건너뛰기
Pentax Optio WG-3 GPS Screen Replacement
필요한 것
  1. Pentax Optio WG-3 GPS Screen Replacement, Screen: 1 단계, 이미지 3개 중 1개 Pentax Optio WG-3 GPS Screen Replacement, Screen: 1 단계, 이미지 3개 중 2개 Pentax Optio WG-3 GPS Screen Replacement, Screen: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using a Philips screwdriver (PH00), remove the 6, 5 mm screws, 4 on each corner and 2 on the sides of the device.
    • One of the side screws is hidden under the top lining of the device.The lining is glued down to the device, you will have to peel the lining back using tweezers. After you are finished with your work you will have to use glue or adhesive to re-stick the lining back to the device.
  2. Pentax Optio WG-3 GPS Screen Replacement: 2 단계, 이미지 1개 중 1개
    • With the small plastic pry tool lift the back of the camera off carefully.
    • Be aware of a few flex cables that connect the mother board to the screen.
    • Open the devices slowly and disconnect the flex cables. When the flex cables have been disconnected you can take the device apart.
  3. Pentax Optio WG-3 GPS Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the 4, 2 mm screws from each corner of the metal screen cover.
    • The larger metal piece is the side the screen is on.
    • Be aware of a detachable metal separator under the top left screw.
  4. Pentax Optio WG-3 GPS Screen Replacement: 4 단계, 이미지 2개 중 1개 Pentax Optio WG-3 GPS Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Detach flex cable and replace screen component.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Allison Merdian
회원 가입일: 03/05/15
422 평판
안내서 4개를 작성함
Sam Houston State, Team 11-4, Blackburne Winter 2015 Sam Houston State, Team 11-4, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S11G4
2 회원들
안내서 8개를 작성함
1가이드 댓글
Any idea where you can buy the replacement screen from? I’m not having any luck finding one. Thank you!
jztmail-1989 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 1,988
