주요 콘텐츠로 건너뛰기
Pentax Optio WP Battery and SD Card Replacement
  1. Pentax Optio WP Battery and SD Card Replacement, Battery and SD Card: 1 단계, 이미지 1개 중 1개
    • The camera used to make this manual does not contain a battery or SD card
    • Orient the camera so you are looking at the bottom and the battery compartment is on the right hand side.
  2. Pentax Optio WP Battery and SD Card Replacement: 2 단계, 이미지 2개 중 1개 Pentax Optio WP Battery and SD Card Replacement: 2 단계, 이미지 2개 중 2개
    • Unlock the battery compartment by sliding the lock switch to the unlock position (away from the arrow).
    • Firmly push the battery cover to the right and swing open.
    • The battery will be located in the larger bottom slot. Slide the plastic orange tab to remove the battery.
    • The SD card will be located in the smaller, top slot. Push the SD card directly in to hear a small clicking sound. Then pull out the SD card.
결론
작성자
7다른 기여자 명과 함께
Olivia Nixon
회원 가입일: 01/16/11
429 평판
안내서 4개를 작성함
Cal Poly, Team 1-13, Amido Winter 2011 Cal Poly, Team 1-13, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G13
5 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 27
전체 시간: 4,603
