주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pentax Optio WP Flash Unit Replacement
필요한 것
    1. Pentax Optio WP Flash Unit Replacement, Battery and SD Card: 1 단계, 이미지 1개 중 1개
      • The camera used to make this manual does not contain a battery or SD card
      • Orient the camera so you are looking at the bottom and the battery compartment is on the right hand side.
      댓글 쓰기
    2. Pentax Optio WP Flash Unit Replacement: 2 단계, 이미지 2개 중 1개 Pentax Optio WP Flash Unit Replacement: 2 단계, 이미지 2개 중 2개
      • Unlock the battery compartment by sliding the lock switch to the unlock position (away from the arrow).
      • Firmly push the battery cover to the right and swing open.
      • The battery will be located in the larger bottom slot. Slide the plastic orange tab to remove the battery.
      • The SD card will be located in the smaller, top slot. Push the SD card directly in to hear a small clicking sound. Then pull out the SD card.
      댓글 쓰기
    1. Pentax Optio WP Flash Unit Replacement, Back Casing: 3 단계, 이미지 2개 중 1개 Pentax Optio WP Flash Unit Replacement, Back Casing: 3 단계, 이미지 2개 중 2개
      • With the battery cover swung open, use the spudger to remove the DC IN sticker.
      • Remove the 4.3 mm silver screw revealed.
      댓글 쓰기
    2. Pentax Optio WP Flash Unit Replacement: 4 단계, 이미지 2개 중 1개 Pentax Optio WP Flash Unit Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Reorient the camera so it is upright and you are looking at the back screen.
      • Remove the rubber covers in the upper and lower right side corners. Insert spudger in between the camera case and the rubber cover and push them out of their sockets. Grab the rubbers with the tweezers and set them aside. Remove both of the 4.3 mm silver screws revealed.
      • Remove the 4.3 mm silver screw in the lower left corner which resides under the sliding battery cover.
      • When removing the screw in the lower left corner, you may need to gently pry open the casing to dislodge the screw.
      댓글 쓰기
    3. Pentax Optio WP Flash Unit Replacement: 5 단계, 이미지 1개 중 1개
      • Locate the 5.3mm silver screw on the edge closest to the upper left corner of the LCD screen and remove it.
      댓글 쓰기
    4. Pentax Optio WP Flash Unit Replacement: 6 단계, 이미지 3개 중 1개 Pentax Optio WP Flash Unit Replacement: 6 단계, 이미지 3개 중 2개 Pentax Optio WP Flash Unit Replacement: 6 단계, 이미지 3개 중 3개
      • With the spudger, pry back the cover starting with the outer edge to release.
      • Lift the back cover off gently from left to right. Be cautious of the copper ribbon attached to the back buttons.
      • Detach the copper ribbon from the internals of the camera by placing a finger on top of the terminal and gently pulling on the back casing.
      댓글 쓰기
    1. Pentax Optio WP Flash Unit Replacement, LCD Screen: 7 단계, 이미지 2개 중 1개 Pentax Optio WP Flash Unit Replacement, LCD Screen: 7 단계, 이미지 2개 중 2개
      • Orient the camera so you are looking at the LCD screen.
      • Using the forceps, remove the red and white wires out of the terminal in the bottom left corner.
      댓글 쓰기
    2. Pentax Optio WP Flash Unit Replacement: 8 단계, 이미지 3개 중 1개 Pentax Optio WP Flash Unit Replacement: 8 단계, 이미지 3개 중 2개 Pentax Optio WP Flash Unit Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the LCD screen from the camera by inserting the spudger between the screen and the metal hook on the right side of the screen and prying up gently.
      • Flip open the black gate holding the copper ribbon from the LCD screen.
      댓글 쓰기
    1. Pentax Optio WP Flash Unit Replacement, Front Casing: 9 단계, 이미지 3개 중 1개 Pentax Optio WP Flash Unit Replacement, Front Casing: 9 단계, 이미지 3개 중 2개 Pentax Optio WP Flash Unit Replacement, Front Casing: 9 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Carefully pry the electronic internals out of the front casing with the spudger.
      • With tweezers, carefully detach the ribbon on the upper right corner of the internals that is connected to the shutter release/power button.
      댓글 쓰기
    1. Pentax Optio WP Flash Unit Replacement, Motherboard and Flash Unit: 10 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Remove the 4 mm black screw on the bottom right corner of the mother board.
      • The black screw may be hard to remove. Use the tweezers if necessary.
      댓글 쓰기
    2. Pentax Optio WP Flash Unit Replacement: 11 단계, 이미지 1개 중 1개
      • With the tweezers, carefully peel back the copper ribbon that was underneath the black screw.
      댓글 쓰기
    3. Pentax Optio WP Flash Unit Replacement: 12 단계, 이미지 1개 중 1개
      • Remove the 2.5 mm silver screw from the upper left corner of the motherboard.
      댓글 쓰기
    4. Pentax Optio WP Flash Unit Replacement: 13 단계, 이미지 2개 중 1개 Pentax Optio WP Flash Unit Replacement: 13 단계, 이미지 2개 중 2개
      • Press down on the metal plate and gently lift the motherboard up from left to right.
      • Be cautious when lifting the motherboard since there is a copper ribbon and two wires attaching the motherboard to the flash unit.
      • Reorient the camera so you are looking at the top edge with the metal plate on the right.
      댓글 쓰기
    1. Pentax Optio WP Flash Unit Replacement, Flash Unit: 14 단계, 이미지 2개 중 1개 Pentax Optio WP Flash Unit Replacement, Flash Unit: 14 단계, 이미지 2개 중 2개
      • Peel back the black plastic revealed under the LCD screen on the metal plate.
      • Remove the two 4.3 mm black screws on the left edge of the metal plate.
      댓글 쓰기
    2. Pentax Optio WP Flash Unit Replacement: 15 단계, 이미지 2개 중 1개 Pentax Optio WP Flash Unit Replacement: 15 단계, 이미지 2개 중 2개
      • Reorient the camera so you are looking at the front with the lens in the upright position.
      • Remove the 4.3 mm black screw in the upper right hand side of the camera as well as the 4.3 mm silver screw in the lower right hand side of the camera.
      • Reorient the camera so you are looking at the back with the metal plate on the right side.
      댓글 쓰기
    3. Pentax Optio WP Flash Unit Replacement: 16 단계, 이미지 3개 중 1개 Pentax Optio WP Flash Unit Replacement: 16 단계, 이미지 3개 중 2개 Pentax Optio WP Flash Unit Replacement: 16 단계, 이미지 3개 중 3개
      • While holding down the black plastic on the right edge of the metal plate, pry the plate up and to the right until it is completely vertical.
      • Lift the metal plate straight up to remove it.
      댓글 쓰기
    4. Pentax Optio WP Flash Unit Replacement: 17 단계, 이미지 1개 중 1개
      • Do not touch the black cylinder on the top edge. This is the capacitor for the flash and it may shock you.
      댓글 쓰기
    5. Pentax Optio WP Flash Unit Replacement: 18 단계, 이미지 3개 중 1개 Pentax Optio WP Flash Unit Replacement: 18 단계, 이미지 3개 중 2개 Pentax Optio WP Flash Unit Replacement: 18 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • With the tweezers, remove the spring on the bottom edge of the battery compartment.
      • Remove the two 4.3 mm silver screws on the inside of this compartment.
      • Lift and remove the flash unit from the left side of the assembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Olivia Nixon
회원 가입일: 01/16/11
429 평판
안내서 4개를 작성함
Cal Poly, Team 1-13, Amido Winter 2011 Cal Poly, Team 1-13, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G13
5 회원들
안내서 27개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 35
전체 시간: 3,114
