주요 콘텐츠로 건너뛰기
Pentax PZ-10 Flash Bulb Replacement
필요한 것
  1. Pentax PZ-10 Flash Bulb Replacement, Opening the Flash Bulb: 1 단계, 이미지 1/1
    • With the camera facing you, open the flash bulb by pushing the grey button to the right of the logo.
  2. Pentax PZ-10 Flash Bulb Replacement, Unscrew Flash Bulb: 2 단계, 이미지 1/2 Pentax PZ-10 Flash Bulb Replacement, Unscrew Flash Bulb: 2 단계, 이미지 2/2
    • Remove the two 5.5 mm JIS #0 screws on the sides of the flash assembly.
  3. Pentax PZ-10 Flash Bulb Replacement, Remove Flash Bulb Cover: 3 단계, 이미지 1/1
    • Gently pull off the flash cover. It should come free with very little force.
  4. Pentax PZ-10 Flash Bulb Replacement, Flash Assembly: 4 단계, 이미지 1/1
    • The flash bulb assembly is now ready for replacement
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bryan Sugiarto
회원 가입일: 04/20/15
252 평판
안내서 2개 작성하였습니다
댓글 2개
Very useful! Great job sir!
michaelsteele1953 - 답글
Do you have a spare part "prism finder" for SLR camera PENTAX Z10 ?
I need only prism repair part enough.
The rangeviewfinder has a middle black tab line bar and the viewer look all yellow colour.
Pitak - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 586
