주요 콘텐츠로 건너뛰기
Pentax PZ-1p Body Panel Removal
필요한 것
  1. Pentax PZ-1p Body Panel Removal, Remove bottom cover: 1 단계, 이미지 3개 중 1개 Pentax PZ-1p Body Panel Removal, Remove bottom cover: 1 단계, 이미지 3개 중 2개 Pentax PZ-1p Body Panel Removal, Remove bottom cover: 1 단계, 이미지 3개 중 3개
    • Unlatch battery compartment door.
    • Remove one 1.7 x 4.0 mm screw.
    • Remove six 1.7 x 2.5 mm shoulder screws.
    • Remove one 1.7 x 2.5 mm long shoulder screw.
    • The bottom cover may be adhered with double sided tape in some locations. Use a spudger to gently work it loose.
  2. Pentax PZ-1p Body Panel Removal, Installation Notes: Bottom cover: 2 단계, 이미지 1개 중 1개
    • Check that the physical panorama switch on the bottom cover and the electrical switch mate properly.
  3. Pentax PZ-1p Body Panel Removal, Remove flash cover: 3 단계, 이미지 3개 중 1개 Pentax PZ-1p Body Panel Removal, Remove flash cover: 3 단계, 이미지 3개 중 2개 Pentax PZ-1p Body Panel Removal, Remove flash cover: 3 단계, 이미지 3개 중 3개
    • Push button to pop up the flash.
    • Remove two 1.7 x 2.5 mm screws.
    • Detach snaps by lifting the side of the flash cover, bending it up and away from the housing.
    • Push flash back down to the stored position.
  4. Pentax PZ-1p Body Panel Removal, Remove top cover screws: 4 단계, 이미지 3개 중 1개 Pentax PZ-1p Body Panel Removal, Remove top cover screws: 4 단계, 이미지 3개 중 2개 Pentax PZ-1p Body Panel Removal, Remove top cover screws: 4 단계, 이미지 3개 중 3개
    • Remove two 1.7 x 2.5 mm screws underneath the pop-up flash.
    • Remove one 1.7 x 2.5 mm panhead screw above the pop-up flash.
    • Remove two 1.7 x 2.5 mm shoulder screws near the eye piece.
  5. Pentax PZ-1p Body Panel Removal, Remove top cover: 5 단계, 이미지 3개 중 1개 Pentax PZ-1p Body Panel Removal, Remove top cover: 5 단계, 이미지 3개 중 2개 Pentax PZ-1p Body Panel Removal, Remove top cover: 5 단계, 이미지 3개 중 3개
    • Remove two 1.7 x 2.5 mm shoulder screws by the strap lugs.
    • Remove one 1.7 x 6.0 mm screw inside the battery compartment.
    • Lift off the top cover.
  6. Pentax PZ-1p Body Panel Removal, Installation Notes: Top cover: 6 단계, 이미지 1개 중 1개
    • Check that the physical power switch and the electrical power switch are both in the same position before installation.
  7. Pentax PZ-1p Body Panel Removal, Remove film door: 7 단계, 이미지 1개 중 1개
    • Push the release latch down to remove the film door.
  8. Pentax PZ-1p Body Panel Removal, Remove front body panel: 8 단계, 이미지 3개 중 1개 Pentax PZ-1p Body Panel Removal, Remove front body panel: 8 단계, 이미지 3개 중 2개 Pentax PZ-1p Body Panel Removal, Remove front body panel: 8 단계, 이미지 3개 중 3개
    • Peel off rubber covering from grip.
    • Remove one 1.7 x 5.0 mm screw.
    • Lift off the front body panel.
결론
작성자
1다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
10,278 평판
안내서 57개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 40
