주요 콘텐츠로 건너뛰기
Pentax PZ-1p Sprocket Counter PCB Replacement
필요한 것
  1. Pentax PZ-1p Sprocket Counter PCB Replacement, Remove bottom cover: 1 단계, 이미지 3개 중 1개 Pentax PZ-1p Sprocket Counter PCB Replacement, Remove bottom cover: 1 단계, 이미지 3개 중 2개 Pentax PZ-1p Sprocket Counter PCB Replacement, Remove bottom cover: 1 단계, 이미지 3개 중 3개
    • Unlatch battery compartment door.
    • Remove one 1.7 x 4.0 mm screw.
    • Remove six 1.7 x 2.5 mm shoulder screws.
    • Remove one 1.7 x 2.5 mm long shoulder screw.
    • The bottom cover may be adhered with double sided tape in some locations. Use a spudger to gently work it loose.
  2. Pentax PZ-1p Sprocket Counter PCB Replacement, Installation Notes: Bottom cover: 2 단계, 이미지 1개 중 1개
    • Check that the physical panorama switch on the bottom cover and the electrical switch mate properly.
  3. Pentax PZ-1p Sprocket Counter PCB Replacement, Remove sprocket counter cover: 3 단계, 이미지 1개 중 1개
    • Remove one screw. This screw is unusual because it has a very steep thread pitch and will want to back out with very little rotation.
    • Use tweezers or a pick to unhook two snaps.
    • Work the cover free. It's a tight fit and will require some wiggling.
    • Installation Notes: Make sure that the sprocket shaft in the film chamber is in the correct position. When the sprocket shaft spins, the sprocket counter should turn as well.
  4. Pentax PZ-1p Sprocket Counter PCB Replacement, Remove gears: 4 단계, 이미지 1개 중 1개
    • Remove two gears.
    • The clear gear has delicate contacts on the underside. Be careful not to deform them.
    • Installation Notes: Align the dots on each gear when reinstalling.
  5. Pentax PZ-1p Sprocket Counter PCB Replacement, Remove sprocket counter PCB: 5 단계, 이미지 1개 중 1개
    • Unsolder three flex connections.
    • Remove the sprocket counter PCB.
결론
Sam Gustafson
회원 가입일: 09/01/22
10,278 평판
안내서 57개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 41
전체 시간: 41
