주요 콘텐츠로 건너뛰기
Pentax Spotmatic Bottom Cover Removal
필요한 것
  1. Pentax Spotmatic Bottom Cover Removal, Remove bottom cover: 1 단계, 이미지 1개 중 1개
    • Remove two X mm flat head screws.
    • Remove bottom cover.
    • This is an example of a properly functioning mirror charging mechanism.
    • The large gear on the far left is driven by the film advance lever on top of the camera.
    • The long silver lever is the mirror charging lever. It pushes the black bar to the top of the slot when the camera is wound, which charges the main mirror spring.
    • The lever on the right holds the black bar in place while the camera is cocked and ready to shoot.
    • At the end of an exposure, the large black gear pushes the release lever, returning the mirror to the viewing position.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
10,278 평판
안내서 57개를 작성함
1가이드 댓글
Fantastic way of showing how the priming and firing mechanism works. A wonderful post mark
mark steed - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 68
전체 시간: 663
