주요 콘텐츠로 건너뛰기
Pentax Spotmatic Slow Speed Governor Cleaning
필요한 것
  1. Pentax Spotmatic Slow Speed Governor Cleaning, Remove frame counter: 1 단계, 이미지 3개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove frame counter: 1 단계, 이미지 3개 중 2개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove frame counter: 1 단계, 이미지 3개 중 3개
    • Loosen three grub screws. Do not remove them from the frame counter cover.
    • Lift off frame counter cover.
    • Remove one 2.5 mm flat head screw. It is reverse or left-hand threaded.
    • Remove the frame counter dial.
    • Remove the retaining nut using a spanner wrench. A pair of fine tipped nippers can also work.
    • On some Spotmatics, this nut may be reverse threaded. Work carefully.
    • Remove the dial seat.
  2. Pentax Spotmatic Slow Speed Governor Cleaning, Remove advance lever: 2 단계, 이미지 3개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove advance lever: 2 단계, 이미지 3개 중 2개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove advance lever: 2 단계, 이미지 3개 중 3개
    • Remove three 2.3 mm flat head screws.
    • Use a pick to rotate the retaining washer until the lobed sections are free.
    • Lift off the advance lever.
    • Remove the plastic shim washer.
  3. Pentax Spotmatic Slow Speed Governor Cleaning, Remove shutter speed dial: 3 단계, 이미지 3개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove shutter speed dial: 3 단계, 이미지 3개 중 2개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove shutter speed dial: 3 단계, 이미지 3개 중 3개
    • Remove one 2.8 mm pin head screw.
    • The dial assembly is spring loaded. Keep two fingers on top of the dial as you are loosening the screw to prevent it from popping off.
    • Remove the shutter speed dial.
    • Remove the ISO dial.
    • Remove the internal spring.
    • Remove the dial housing.
  4. Pentax Spotmatic Slow Speed Governor Cleaning, Installation Notes: Shutter Speed Dial: 4 단계, 이미지 2개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Installation Notes: Shutter Speed Dial: 4 단계, 이미지 2개 중 2개
    • The hole in the dial housing needs to go over the tab on the speed resistor.
    • The tab on the ISO dial needs to mate with the hole in the dial housing.
    • It can be difficult to line everything up while compressing the spring and installing the center screw. Be patient.
  5. Pentax Spotmatic Slow Speed Governor Cleaning, Remove film winder assembly: 5 단계, 이미지 3개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove film winder assembly: 5 단계, 이미지 3개 중 2개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove film winder assembly: 5 단계, 이미지 3개 중 3개
    • Place a thin, sturdy tool in the spindle fork.
    • Unscrew the rewind knob.
    • Use a spanner wrench to unscrew the retaining nut.
    • Remove the film reminder
    • Remove the spring washer.
    • Remove the friction plate.
  6. Pentax Spotmatic Slow Speed Governor Cleaning, Remove top cover: 6 단계, 이미지 2개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove top cover: 6 단계, 이미지 2개 중 2개
    • Remove one 3.0 mm flat head screw.
    • Remove top cover.
  7. Pentax Spotmatic Slow Speed Governor Cleaning, Remove bottom cover: 7 단계, 이미지 1개 중 1개
    • Remove two X mm flat head screws.
    • Remove bottom cover.
    • This is an example of a properly functioning mirror charging mechanism.
    • The large gear on the far left is driven by the film advance lever on top of the camera.
    • The long silver lever is the mirror charging lever. It pushes the black bar to the top of the slot when the camera is wound, which charges the main mirror spring.
    • The lever on the right holds the black bar in place while the camera is cocked and ready to shoot.
    • At the end of an exposure, the large black gear pushes the release lever, returning the mirror to the viewing position.
  8. Pentax Spotmatic Slow Speed Governor Cleaning, Unsolder meter circuit: 9 단계, 이미지 2개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Unsolder meter circuit: 9 단계, 이미지 2개 중 2개
    • Unscrew or unsolder one black wire. This is the main power coming from the meter switch on the side of the mirror box.
    • Unscrew one blue wire. This is the ground wire that connects the meter circuit to the body of the camera.
    • Unsolder one yellow and one black wire from the speed resistor.
  9. Pentax Spotmatic Slow Speed Governor Cleaning, Remove viewfinder assembly: 10 단계, 이미지 2개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove viewfinder assembly: 10 단계, 이미지 2개 중 2개
    • Remove three 5.7 mm flat head screws.
    • Lift out the viewfinder assembly.
    • The pentaprism, eye piece and meter circuit will come out with the viewfinder.
  10. Pentax Spotmatic Slow Speed Governor Cleaning, Remove self timer lever: 11 단계, 이미지 2개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove self timer lever: 11 단계, 이미지 2개 중 2개
    • Remove cover screw using a spanner wrench.
    • Remove the self timer lever. The internal mechanism will unwind past the installed position when the lever is removed.
    • Installation Note: Temporarily place the lever on the post 90° counter-clockwise to its installed position. Wind the self timer. Remove the lever and place it in its installed position. Release the self timer.
  11. Pentax Spotmatic Slow Speed Governor Cleaning, Remove leatherette: 12 단계, 이미지 3개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove leatherette: 12 단계, 이미지 3개 중 2개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove leatherette: 12 단계, 이미지 3개 중 3개
    • Apply isopropyl alcohol to the edge of the leatherette covering to soften the adhesive.
    • Use a dull scraper to get under the edge of the leatherette and begin peeling it off.
    • Fully remove the leatherette covering from both sides of the camera.
    • If the self timer lever can't be removed, the leatherette can be peeled away just enough to access the screws.
    • Installation Note: Use contact cement or shellac to reapply the leatherette.
  12. Pentax Spotmatic Slow Speed Governor Cleaning, Remove front lens board: 13 단계, 이미지 3개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove front lens board: 13 단계, 이미지 3개 중 2개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove front lens board: 13 단계, 이미지 3개 중 3개
    • Remove four 4.6 mm flat head screws.
    • Remove one 4.3 mm flat head screws.
    • Lift off front lens board.
    • Note the position and number of shim washers at each screw location. They need to be installed in the same positions during reassembly.
    • If the top cover is still attached, lift the bottom of the lens board first. There is a lip around the top of the lens mount that engages with the top.
  13. Pentax Spotmatic Slow Speed Governor Cleaning, Remove mirror return spring: 14 단계, 이미지 2개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove mirror return spring: 14 단계, 이미지 2개 중 2개
    • Unhook mirror return spring.
    • Unscrew one 4.8 mm flat head shoulder screw.
    • Remove keyed washer.
  14. Pentax Spotmatic Slow Speed Governor Cleaning, Unsolder wired connections: 15 단계, 이미지 2개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Unsolder wired connections: 15 단계, 이미지 2개 중 2개
    • Unsolder two red wires. These connect to the X-sync contact.
    • Unsolder one black wire. This connects to the battery compartment contact.
    • Pull black meter wire through the whole in the chassis.
  15. Pentax Spotmatic Slow Speed Governor Cleaning, Remove mirror box: 16 단계, 이미지 2개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove mirror box: 16 단계, 이미지 2개 중 2개
    • Remove one 4.3 mm flat head screw.
    • Remove one 4.5 mm flat head shoulder screw.
    • Lift mirror box up and over posts on the back of the camera. The posts can be removed for easier removal and installation if necessary.
  16. Pentax Spotmatic Slow Speed Governor Cleaning, Installation Notes: Mirror Box: 17 단계, 이미지 2개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Installation Notes: Mirror Box: 17 단계, 이미지 2개 중 2개
    • The shutter should be released before installing the mirror box.
    • The mirror charging lever needs to be behind the mirror actuator lever coming from the mirror box.
    • The post from the shutter release shaft should be above the mirror release lever on the mirror box.
  17. Pentax Spotmatic Slow Speed Governor Cleaning, Firing the shutter: 18 단계, 이미지 1개 중 1개
    • With the mirror box removed, the shutter can be fired by pushing the shutter release bar...
    • and releasing the opening curtain latch
  18. Pentax Spotmatic Slow Speed Governor Cleaning, Remove tripod mount: 19 단계, 이미지 1개 중 1개
    • Remove two 3.5 mm flat head screws.
  19. Pentax Spotmatic Slow Speed Governor Cleaning, Remove slow speed governor: 20 단계, 이미지 2개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Remove slow speed governor: 20 단계, 이미지 2개 중 2개
    • Remove two 2.8 mm flat head screws.
    • Installation Notes: Ensure that the pallet rod and delay rod are properly coupled to the slow speed governor.
  20. Pentax Spotmatic Slow Speed Governor Cleaning, Clean and lubricate slow speed governor: 21 단계, 이미지 3개 중 1개 Pentax Spotmatic Slow Speed Governor Cleaning, Clean and lubricate slow speed governor: 21 단계, 이미지 3개 중 2개 Pentax Spotmatic Slow Speed Governor Cleaning, Clean and lubricate slow speed governor: 21 단계, 이미지 3개 중 3개
    • Clean the slow speed governor by soaking it in isopropyl alcohol to loosen dirt and grime.
    • Actuate the gear train repeatedly to work contaminates free. An ultrasonic cleaner can also be used if available.
    • Once dry, lubricate six pivot points with shutter oil to ensure consistent operation.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
10,278 평판
안내서 57개를 작성함
1가이드 댓글
Aweome guide, thanks!! Maybe in the future I would have the confidence to try it 😅😅 Thanks again!
Luis Calderón - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 52
전체 시간: 649
