주요 콘텐츠로 건너뛰기
Pentax Spotmatic Top Cover Removal
필요한 것
  1. Pentax Spotmatic Top Cover Removal, Remove frame counter: 1 단계, 이미지 3개 중 1개 Pentax Spotmatic Top Cover Removal, Remove frame counter: 1 단계, 이미지 3개 중 2개 Pentax Spotmatic Top Cover Removal, Remove frame counter: 1 단계, 이미지 3개 중 3개
    • Loosen three grub screws. Do not remove them from the frame counter cover.
    • Lift off frame counter cover.
    • Remove one 2.5 mm flat head screw. It is reverse or left-hand threaded.
    • Remove the frame counter dial.
    • Remove the retaining nut using a spanner wrench. A pair of fine tipped nippers can also work.
    • On some Spotmatics, this nut may be reverse threaded. Work carefully.
    • Remove the dial seat.
  2. Pentax Spotmatic Top Cover Removal, Remove advance lever: 2 단계, 이미지 3개 중 1개 Pentax Spotmatic Top Cover Removal, Remove advance lever: 2 단계, 이미지 3개 중 2개 Pentax Spotmatic Top Cover Removal, Remove advance lever: 2 단계, 이미지 3개 중 3개
    • Remove three 2.3 mm flat head screws.
    • Use a pick to rotate the retaining washer until the lobed sections are free.
    • Lift off the advance lever.
    • Remove the plastic shim washer.
  3. Pentax Spotmatic Top Cover Removal, Remove shutter speed dial: 3 단계, 이미지 3개 중 1개 Pentax Spotmatic Top Cover Removal, Remove shutter speed dial: 3 단계, 이미지 3개 중 2개 Pentax Spotmatic Top Cover Removal, Remove shutter speed dial: 3 단계, 이미지 3개 중 3개
    • Remove one 2.8 mm pin head screw.
    • The dial assembly is spring loaded. Keep two fingers on top of the dial as you are loosening the screw to prevent it from popping off.
    • Remove the shutter speed dial.
    • Remove the ISO dial.
    • Remove the internal spring.
    • Remove the dial housing.
  4. Pentax Spotmatic Top Cover Removal, Installation Notes: Shutter Speed Dial: 4 단계, 이미지 2개 중 1개 Pentax Spotmatic Top Cover Removal, Installation Notes: Shutter Speed Dial: 4 단계, 이미지 2개 중 2개
    • The hole in the dial housing needs to go over the tab on the speed resistor.
    • The tab on the ISO dial needs to mate with the hole in the dial housing.
    • It can be difficult to line everything up while compressing the spring and installing the center screw. Be patient.
  5. Pentax Spotmatic Top Cover Removal, Remove film winder assembly: 5 단계, 이미지 3개 중 1개 Pentax Spotmatic Top Cover Removal, Remove film winder assembly: 5 단계, 이미지 3개 중 2개 Pentax Spotmatic Top Cover Removal, Remove film winder assembly: 5 단계, 이미지 3개 중 3개
    • Place a thin, sturdy tool in the spindle fork.
    • Unscrew the rewind knob.
    • Use a spanner wrench to unscrew the retaining nut.
    • Remove the film reminder
    • Remove the spring washer.
    • Remove the friction plate.
  6. Pentax Spotmatic Top Cover Removal, Remove top cover: 6 단계, 이미지 2개 중 1개 Pentax Spotmatic Top Cover Removal, Remove top cover: 6 단계, 이미지 2개 중 2개
    • Remove one 3.0 mm flat head screw.
    • Remove top cover.
결론
작성자
1다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
10,278 평판
안내서 57개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 42
전체 시간: 849
