주요 콘텐츠로 건너뛰기
Pentax ZX-5n Sprocket Counter PCB Replacement
필요한 것
  1. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove back cover: 1 단계, 이미지 1개 중 1개
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove bottom cover: 2 단계, 이미지 1개 중 1개
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove left front cover: 3 단계, 이미지 1개 중 1개
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove front cover: 4 단계, 이미지 2개 중 1개 Pentax ZX-5n Sprocket Counter PCB Replacement, Remove front cover: 4 단계, 이미지 2개 중 2개
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove right front cover: 5 단계, 이미지 1개 중 1개
    • Remove two 3.9 mm #00 screws.
  6. Pentax ZX-5n Sprocket Counter PCB Replacement, Prepare bottom plate: 6 단계, 이미지 2개 중 1개 Pentax ZX-5n Sprocket Counter PCB Replacement, Prepare bottom plate: 6 단계, 이미지 2개 중 2개
    • Remove two 3.4 mm #00 screws. Remove the plate holding the contacts in place.
    • Peel tape from the plate. Leave the tape attached to the flex circuit.
    • Remove the flex circuits from their retaining studs.
  7. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove bottom plate: 7 단계, 이미지 2개 중 1개 Pentax ZX-5n Sprocket Counter PCB Replacement, Remove bottom plate: 7 단계, 이미지 2개 중 2개
    • Remove one 3.3 mm #0 countersunk screw.
    • Remove one 3.9 mm #0 shoulder screw.
    • Remove four 3.3 mm #00 screws.
    • Pull a little slack through the housing on this flex cable.
    • Pop the plate off its posts, rotate slightly clockwise and pull gently through the loosened flex cable.
    • To the camera tech that left me a happy little note...I see you.
  8. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove transport gears: 8 단계, 이미지 2개 중 1개 Pentax ZX-5n Sprocket Counter PCB Replacement, Remove transport gears: 8 단계, 이미지 2개 중 2개
    • It's best to remove these parts now so they don't fall out later on in the repair.
  9. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove transport gear carrier: 9 단계, 이미지 3개 중 1개 Pentax ZX-5n Sprocket Counter PCB Replacement, Remove transport gear carrier: 9 단계, 이미지 3개 중 2개 Pentax ZX-5n Sprocket Counter PCB Replacement, Remove transport gear carrier: 9 단계, 이미지 3개 중 3개
    • Gently pull the speaker from its retention posts.
    • Remove two 5.1 mm #00 screws.
    • Installation Notes: The transport gear carrier mates with the sprocket shaft here using a squared off spindle. Make sure they mate properly when reassembled.
  10. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove sprocket counter PCB: 10 단계, 이미지 2개 중 1개 Pentax ZX-5n Sprocket Counter PCB Replacement, Remove sprocket counter PCB: 10 단계, 이미지 2개 중 2개
    • Remove one X mm screw.
    • Unsolder one purple wire.
    • Unsolder one yellow wire.
결론
작성자
1다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
7,682 평판
안내서 42개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 17
전체 시간: 17
