주요 콘텐츠로 건너뛰기
Pentax ZX-5n Top Cover Replacement
필요한 것
  1. Pentax ZX-5n Top Cover Replacement, Remove back cover: 1 단계, 이미지 1개 중 1개
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Pentax ZX-5n Top Cover Replacement, Remove bottom cover: 2 단계, 이미지 1개 중 1개
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Pentax ZX-5n Top Cover Replacement, Remove left front cover: 3 단계, 이미지 1개 중 1개
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Pentax ZX-5n Top Cover Replacement, Remove front cover: 4 단계, 이미지 2개 중 1개 Pentax ZX-5n Top Cover Replacement, Remove front cover: 4 단계, 이미지 2개 중 2개
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Pentax ZX-5n Top Cover Replacement, Remove right front cover: 5 단계, 이미지 1개 중 1개
    • Remove two 3.9 mm #00 screws.
  6. Pentax ZX-5n Top Cover Replacement, Remove eye cup: 6 단계, 이미지 1개 중 1개
    • Slide the eye cup up and off to access the screws underneath.
  7. Pentax ZX-5n Top Cover Replacement, Unscrew top cover: 7 단계, 이미지 3개 중 1개 Pentax ZX-5n Top Cover Replacement, Unscrew top cover: 7 단계, 이미지 3개 중 2개 Pentax ZX-5n Top Cover Replacement, Unscrew top cover: 7 단계, 이미지 3개 중 3개
    • Remove two 5.3 mm #00 screws by the eyepiece.
    • Remove one 6.8 mm #00 screw in the battery compartment.
    • Remove one 7.0 mm #00 screw near the take up spool.
  8. Pentax ZX-5n Top Cover Replacement, Lift top cover: 8 단계, 이미지 1개 중 1개
    • Lift the cover so it is just free of the body. It is still attached by several wires.
  9. Pentax ZX-5n Top Cover Replacement, Discharge flash capacitors: 9 단계, 이미지 1개 중 1개
    • Use a 1kΩ-10kΩ resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
  10. Pentax ZX-5n Top Cover Replacement, Unsolder flash connections: 10 단계, 이미지 1개 중 1개
    • Unsolder one green wire.
    • Unsolder one blue wire.
    • Unsolder one brown wire.
    • Unsolder one black wire.
  11. Pentax ZX-5n Top Cover Replacement, Unsolder remaining connections: 11 단계, 이미지 3개 중 1개 Pentax ZX-5n Top Cover Replacement, Unsolder remaining connections: 11 단계, 이미지 3개 중 2개 Pentax ZX-5n Top Cover Replacement, Unsolder remaining connections: 11 단계, 이미지 3개 중 3개
    • Pull black wire out from its routed location.
    • Unsolder flex connector
    • Be careful not to overheat the flex circuit. Work in short durations. Allow for cool downs in between if necessary.
    • Some repairs can be performed with the top cover still connected but the flex connection is fragile and easily damaged.
결론
작성자
1다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
7,682 평판
안내서 42개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 10
