주요 콘텐츠로 건너뛰기
Petmate 29027 Fountain Lid and Pump Replacement
필요한 것
  1. Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: 1 단계, 이미지 1/3 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: 1 단계, 이미지 2/3 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: 1 단계, 이미지 3/3
    • Unplug the fountain from the electrical source and disconnect the inline plug.
    • Remove the lid.
    • Empty water from the fountain
    • Reach in the bowl and lift up the pump.
  2. Petmate 29027 Fountain Lid and Pump Replacement: 2 단계, 이미지 1/3 Petmate 29027 Fountain Lid and Pump Replacement: 2 단계, 이미지 2/3 Petmate 29027 Fountain Lid and Pump Replacement: 2 단계, 이미지 3/3
    • Unclip the lid and intake plate using a fingernail.
  3. Petmate 29027 Fountain Lid and Pump Replacement: 3 단계, 이미지 1/2 Petmate 29027 Fountain Lid and Pump Replacement: 3 단계, 이미지 2/2
    • Pry out the impeller (4 white bladed propellers) which is held in place magnetically.
    • You can use a fingernail or small needle nose pliers to get under the plastic blade and lift it out.
  4. Petmate 29027 Fountain Lid and Pump Replacement: 4 단계, 이미지 1/3 Petmate 29027 Fountain Lid and Pump Replacement: 4 단계, 이미지 2/3 Petmate 29027 Fountain Lid and Pump Replacement: 4 단계, 이미지 3/3
    • Clean the parts with warm soapy water and reassemble them.
    • Be sure to rinse thoroughly with fresh water.
    • Cleaning the motor with white vinegar (150ml) can increase disinfecting and hard water removal.
  5. Petmate 29027 Fountain Lid and Pump Replacement: 5 단계, 이미지 1/2 Petmate 29027 Fountain Lid and Pump Replacement: 5 단계, 이미지 2/2
    • Replace the pump into the original location.
    • Press down on the pump to engage the suction cups.
    • Place the fountain lid in the right place.
  6. Petmate 29027 Fountain Lid and Pump Replacement: 6 단계, 이미지 1/2 Petmate 29027 Fountain Lid and Pump Replacement: 6 단계, 이미지 2/2
    • Replug the fountain into electricity.
    • Add water as needed.
    • Never let the water level fall lower than the min fill line.
결승점
Shidie Ren
회원 가입일: 05/11/20
133 평판
안내서 1개 작성함
York University, Team S1-G22, O'Regan Summer 2020 York University, Team S1-G22, O'Regan Summer 2020 회원
YORK-O'REGAN-SU20S1G22
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 30
전체 시간: 510
