주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Petnet SmartFeeder SF10E 12 Pin Connector Replacement
필요한 것
  1. Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: 1 단계, 이미지 3개 중 1개 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: 1 단계, 이미지 3개 중 2개 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: 1 단계, 이미지 3개 중 3개
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
  2. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 2 단계, 이미지 3개 중 1개 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 2 단계, 이미지 3개 중 2개 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
  3. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
    • It should come off easily.
  4. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 4 단계, 이미지 1개 중 1개
    • Flip over the SmartFeeder by using both hands.
    • Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
  5. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 5 단계, 이미지 2개 중 1개 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 5 단계, 이미지 2개 중 2개
    • Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section.
    • Place the bottom piece of the device right-side up.
  6. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 6 단계, 이미지 2개 중 1개 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 6 단계, 이미지 2개 중 2개
    • Remove one 10 mm screw by using the Phillips #1 screwdriver.
    • Remove the plastic retaining piece for the daughterboard by pulling it out with one hand.
  7. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 7 단계, 이미지 3개 중 1개 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 7 단계, 이미지 3개 중 2개 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 7 단계, 이미지 3개 중 3개
    • Pull the daughterboard out of the device and remove the three-prong connectors by using your hands.
    • Hold onto the sockets on the motherboard or you could accidentally pull off the entire assembly.
결론
작성자
3다른 기여자 명과 함께
Ashley Kim
회원 가입일: 10/08/18
187 평판
안내서 1개를 작성함
Cal Poly, Team S13-G7, White Fall 2018 Cal Poly, Team S13-G7, White Fall 2018 회원
CPSU-WHITE-F18S13G7
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 51
전체 시간: 542
