주요 콘텐츠로 건너뛰기
Petnet SmartFeeder SF10E 12 Pin Connector Replacement
필요한 것
  1. Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: 1 단계, 이미지 1/3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: 1 단계, 이미지 2/3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: 1 단계, 이미지 3/3
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
  2. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 2 단계, 이미지 1/3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 2 단계, 이미지 2/3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 2 단계, 이미지 3/3
    • Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
  3. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 3 단계, 이미지 1/1
    • Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
    • It should come off easily.
  4. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 4 단계, 이미지 1/1
    • Flip over the SmartFeeder by using both hands.
    • Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
  5. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 5 단계, 이미지 1/2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 5 단계, 이미지 2/2
    • Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section.
    • Place the bottom piece of the device right-side up.
  6. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 6 단계, 이미지 1/2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 6 단계, 이미지 2/2
    • Remove one 10 mm screw by using the Phillips #1 screwdriver.
    • Remove the plastic retaining piece for the daughterboard by pulling it out with one hand.
  7. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 7 단계, 이미지 1/3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 7 단계, 이미지 2/3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 7 단계, 이미지 3/3
    • Pull the daughterboard out of the device and remove the three-prong connectors by using your hands.
    • Hold onto the sockets on the motherboard or you could accidentally pull off the entire assembly.
결론
Ashley Kim
회원 가입일: 10/08/18
187 평판
안내서 1개 작성함
Cal Poly, Team S13-G7, White Fall 2018 Cal Poly, Team S13-G7, White Fall 2018 회원
CPSU-WHITE-F18S13G7
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 316
