주요 콘텐츠로 건너뛰기
Petnet SmartFeeder SF10E Battery Replacement
필요한 것
  1. Petnet SmartFeeder SF10E Battery Replacement, Battery: 1 단계, 이미지 1/3 Petnet SmartFeeder SF10E Battery Replacement, Battery: 1 단계, 이미지 2/3 Petnet SmartFeeder SF10E Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
    • Remove the metal tray by using both hands and pulling out the bowl towards you.
  2. Petnet SmartFeeder SF10E Battery Replacement: 2 단계, 이미지 1/2 Petnet SmartFeeder SF10E Battery Replacement: 2 단계, 이미지 2/2
    • Turn the bowl tray side down by using both hands.
    • Remove seven 11 mm screws by using the Phillips #1 screwdriver.
  3. Petnet SmartFeeder SF10E Battery Replacement: 3 단계, 이미지 1/2 Petnet SmartFeeder SF10E Battery Replacement: 3 단계, 이미지 2/2
    • Take the battery out of the SmartBowl with tweezers, avoid pulling on any wires.
    • Hold the SmartBowl down using one hand while using the other hand to remove the battery.
  4. Petnet SmartFeeder SF10E Battery Replacement: 4 단계, 이미지 1/2 Petnet SmartFeeder SF10E Battery Replacement: 4 단계, 이미지 2/2
    • Remove the tape, closest to the four white connectors, with your hands.
    • Keep the wires attached to the tape for easy reassembly.
  5. Petnet SmartFeeder SF10E Battery Replacement: 5 단계, 이미지 1/2 Petnet SmartFeeder SF10E Battery Replacement: 5 단계, 이미지 2/2
    • Trace the wires with your hands from the battery to the motherboard.
    • Detach the three-prong connector between the battery and the motherboard by pulling the white connectors with your hands.
    • Hold on to the sockets on the motherboard or you could accidentally pull off the entire assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kristin Villanueva
회원 가입일: 10/08/18
370 평판
안내서 2개 작성하였습니다
Cal Poly, Team S13-G7, White Fall 2018 Cal Poly, Team S13-G7, White Fall 2018 회원
CPSU-WHITE-F18S13G7
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 538
