소개
Use this guide to replace your charging assembly if it is damaged and cannot connect to the USB charging cable. When working with electrical components, use steady hands and touch as little of the circuitry as possible.
부품
지정된 부품이 없습니다.
Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
Remove the metal tray by using both hands and pulling out the bowl towards you.
거의 끝나갑니다!
결론
